Check the pulleys, just tighten the screws of every single one, the problem is to access the motor pulleys, but that ones are the most important (or just as important)
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#shifted
kmanstudios 1,117
Ummm, I am not sure what you mean by 'further than the original'. Was this in one axis only? What did you use to slice it with and do you have a screenshot of the file to compare against the printed piece?
And, welcome to da forum. I am not a welcomer, but am a noob, not much further than yourself.
