A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
ultiarjan 1,223
I would just order a replacement fan from the closest Ultimaker reseller, if you do this it also has the correct connector.
The ultimaker partnumber is 1313.
When you do source elsewhere you also must make sure the fan supports PWM.
Model Cooling Fan 12VDC 0.1 A
30x30x10
connector JST XHP-2
horizoncdr 0
Because the 2 are in series you need to have 2 identical fans.
