I have that issue on the Ultimaker 2+ and always do the Move Material function prior to a print to prime the print head.
On the Ultimaker 3, I have only had this happen once, even with the latest version of the firmware. I'd re-check the firmware for the latest. One the 5 prints I have done so far on the UM3 I have here, it's only done this once. (I manually moved material on each nozzle then did the print.)
tomnagel 123
This is strange behaviour. Though I don't recognise the problem, updating your firmware to the latest version is always a good idea. Did you do that?
And which slicer did you use?
Does this always happen? Also when the previous print was ended successfully?
