upgraded from 2.4 to 2.6 beta. i used to select an object then zoom using double finger slide down on the trackpad, this used to zoom into the object.
This feature has been disabled on Windows, because it caused a crash. The crash happens in an external bit of code, so it has proven tricky to fix so far.
dintid 6
Thanks!!
I've actually been looking at other slizers as the placement of objects and slow auto-slizing and startup was a huge bother.
Glad you finally put back in a proper object placemnet feature. It's been defunct since v2.* where items goes way out of the printplate. I havn't tested it yet though
Adding option to disable auto-slizing and supporting multi-threadding is very nice (why wait so long for this?)
Requests
As it is now we have to remember a wealth of information for each of our filaments and it's just impossible to do so. S3D and Sliz3r has all kinds of nice settings for filaments, which are really a must have.
ahoeben 1,944
This only happens on the first time you run Cura, from the installer. Restart Cura, problem solved.
