kmanstudios 1,120
I agree with gr5 on the strings. Different materials do create interesting situations, but clean up of that is minimal. And, since, for the most part, I go about finishing up the print by way of sanding, priming and painting for the most part, Those are really small issues for me.
And, having built a gazillion commercial models, it is less trouble than trimming the flashing or even warping that heat or improper storage (or worse, just a bad series in the commercial lineup/production run) can do to a commercial model over time or even fresh purchases.
gr5 2,069
@dim3nsioneer sells some nice swiss filaments.
Do you mean those small strings? Those are very small and easy to clean up. Not so easy to fix. I'm not sure what causes them but white filaments (all brands!) tend to be worse.
