Apparently one of the magnets had fallen out of the holster (and had become twisted around the steel pole) - gluing it back into place fixed the issue. Thanks!
Can you share a picture? it usually helps.
Normally the magnets touch the 2 front long screws to hold on to... is there something stopping the lid to close completely? Is the "silicone nozzle cover" properly seated? are the little metal "wings" on the bottom metal plate not bend (check if left and right look the same).
ultiarjan 1,222
