Good to know! Thanks for the reply.
Hey Don,
if you want to avoid using USB stick/SD card between devices and also get the most out of your printer, you can try connecting your printer to 3DPrinterOS cloud.
DM me (alex at 3dprinteros dot com) for more info.
ahoeben 1,888
You are experiencing a "memory leak". For some reason Cura keeps allocating a small amount of memory at a time and not releasing it back. It has been reported one or two times, but so far it has not been reproduced so it is hard to fix.
Note that you don't have to keep Cura open while the UM3 is printing via network printing. The full gcode has already been transferred to the printer and it is safe to close (and later reopen) Cura while the printer is running.
