Arduino Mega G-Code FWD
Posted · Arduino Mega G-Code FWD
Hello Community
I'm trying to connect an second arduino with the Mega from the Ultimaker electronics. My plan was to connect the second to an free RX/TX port on the Mega to add an custom G-Code for changing the color. (e.g G66 255, 255, 255)
I don't know if the electronics uses the PWM outputs from the Mega. If so, I need an extra board. If not - direct attach the Dioder Lights to the Mega with a Darlington Array and an extra power supply. (from here: http://ikennd.ac/blog/2011/09/arduino-dioder-part-one/)
An example would be to change the Color every line or to change the light when finished printing with start end G-Code)
Can somebody help me with the programming in Marlin and tell me wich pins are reserved/used?
Greets, Noc
    Yeah, thanks for that Link!
    So I'll have to use expansion 3. Based on 2 RGB Channels, I need 6 PWM outputs.
    The 1.5.7 Electronic has an LEDs output Pin. How much Power does it support?
    I messured 18,8V. That would be perfect for the Dioder (with a step-down Board)
    The Wiki says: "A PWM output with power for LED arrays and other lighting"
    What is the exact current?
    Thanks!
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 17 replies
