To be complete, the core has 5 metal contacts at the back, if you measure you measure the two most left or the 2 most right (I forgot which is which..). One pair is the heater, with a resistance as Tom mentioned, the other pair is the PT100, the temp sensor, with a resistance around 108 ohm (at +/- 20 degrees C) .
1
tomnagel 123
Looks like the heater in the second AA core draws too much current, which makes the power supply cut power.
If you have a multimeter at hand, you can measure the electrical resistance of the heater. It should be typically 23 Ohm (21.9 - 25.6Ohm)
And if you reinsert the BB core and force active leveling (which heats up both print cores), this does not happen?
