I'm having the same problem.
fbrc8-erin 265
If you're looking for a good support material for ABS, the new breakaway support material works great with it.
I just ordered some of the Break Away. Looking for a solution that works with the higher temp build materials. I've also tried Scaffold Snap (E3D) but I can't get it to work with ABS any better than the HIPS. Hopefully Ultimakers' Break Away isn't the same as Scaffold Snap.
bietenbot 0
I currently struggle with the same problem and am still looking for a solution..
My guess is that the the ABS, where I want to print the HIPS on top, is cooled down too much during printing of my large model (20 x 20 cm).
