37% into print repeatable extruder clicking
Octocom
Posted · 37% into print repeatable extruder clicking
Hi All,
What should I check when the extruder starts clicking from 37% into print everytime, it seems to happen when it get to a certain layer height. the first set of layers are perfect around 3mm.
Luke
    Hi @Octocom,
    Thank you for your message and welcome to the community!
    Could you share with us what Ultimaker 3D printer you have?
    With how many prints have you seen this behavior? Is your Ultimaker new?
    It sounds like, at some point your feeder gets a little bit more resistance during the print. This can have several reasons, if you can provide us with some more information we should be able to help you isolate the problem and get you back to quiet 3D printing! :)
        • 9 replies
