axes dont move
iods
Posted · axes dont move
HELLO MY DEAREST 3D MASTERS
i just finished the assembling of my 3d printer..original+ but when i select the auto home the axes are not moving, only the bed. i double checked my cables and everything looks fine.
any idea?
thank you in advance
    Hello,
    I had this problem once.
    Is it possible to invert the motor cable of your table with that of one of the X or Y axis motors? This test can verify the integrity of the cables, motors and drivers on the board.
    Hope to hear from you.
    Well guyz the motors are making a mini-noise when im choosing the auto home but then only the bed is moving (is going up) the axes are not moving at all and the blue screen is showing ultimaker ready.
    im sending you some pictures to help me out
    if you notice any problem please let me know
    thanx for you time hope i can finally use my 3d printer.
    cheers
    19198599_10208805915964432_1565236851_n.jpg?oh=1da7d743e841e7cf5a9c44d75107da53&oe=5943513919238461_10208805915484420_1375799006_o.jpg?oh=80adeeb7b03950fae2e70aa3eb4912b6&oe=5944575219142349_10208805915644424_1580341485_n.jpg?oh=cce7c5d89d39fed8cecbaeb59e010708&oe=5944381219205112_10208805915524421_1240290290_o.jpg?oh=0e3bd2505e9212b5d948ab5b00264a56&oe=59434C8D19190750_10208805915804428_1033879378_n.jpg?oh=6400942bad2a886d51b7755c9c30f4d3&oe=59436A68
    I tried again the auto home and before that i ex-change the x with the y axes on the cables of the motors back on the board. the monitors are shaking but the washers are not doing any movement so the axes again are not moving at all
    If your motors sound like they're trying to move, but the printhead isn't going anywhere, I'd double check that your pulleys are all tight on the motors and the rods.
    The short belt is toooo loose. Unscrew a bit the 4 screws, push it down and tighten it again (while you keep pushing down).
    Hello,
    Could you check if, when you 're moving the head in x and y direction ,with your hand, you turn your x or y motor?
    This operation can help you to check all the mechanical link.
        • 8 replies
