Heated Bed Errors - Screw Terminal? pt100?
Posted (edited) · Heated Bed Errors - Screw Terminal? pt100?
Hello Ultimaker community,
It's been a while since I've had to post any hardware issues, but my heated bed has started acting up recently. Either the pt100 returns a temperature of 55 degrees (even at room temp.) and thus stops heating the bed, causing it to cool down (and prints just pop right off), or I get the MAXTEMP BED error.
I've gone through to check the connections multiple times, and I do not see any issue. However, one thing did catch my eye, and it threw me off a bit:
As you can see, the third screw terminal is missing the copper plate (or whatever it is) at the back (all of the terminals are wide open). It is one of the terminals for the heater itself, not the pt100. Should I be concerned?
Additionally, I measured the resistance on the pt100 at room temp, and it started off pretty consistent at around 111 ohms, but as soon as my hand would twitch a bit, it would hike up to the 120's, 130's, 140's, sometimes even the 200's, then drop back down in a matter of seconds. When I turned the machine on, though, the temperature seemed pretty steady. Is this normal? Should I attempt resoldering the connections (I'm already out of warranty)?
Thank you,
nerdwarrior
    Posted · Heated Bed Errors - Screw Terminal? pt100?
    Add-on: My bed was consistently reading around 6 degrees higher than the hotend at room temp, which I never really paid attention to, but after properly redoing all connections, they are back at the same temperature. However, I'm still concerned about both the fluctuating resistance and the terminal.
    Hi nerdwarrior,
    You should change this Terminal Block.
    Here is a picture I made from the terminal block to see the connector lip in half way closed position.
    The material in here is Tin plated Copper. Maybe we can see this lip if you turn the screw clockwise to lift the lip. Did the wires for the heat bed show any sign of overheated, burnt black etc.?
    If you touch (trying to heat) the PT100 resistor with your finger, there should not be any big jump in the reading - maybe 1 ohm "more", this cause the aluminium plate is connected to the resistor.
    Here is the P/N number of the used Terminal Block:
    MKDS 1/ 4-3,81 SMD
    And here is where you find them:
    http://www.tme.eu/gb/details/mkds1_4-3.81smd/pcb-terminal-blocks/phoenix-contact/mkds-1-4-381-smd-bk-1727256/
    OK., good luck.
    Thanks
    Torgeir.
    Hi nerdwarrior,
    MKDS 1/ 4-3,81 SMD
    OK., good luck.
    Thanks
    Torgeir.
    Thank you so much @Torgeir!
    A metal plate does lift up and close the opening if I close the terminals, but it is missing the plate at the back. The wires also seem fine, but I will go ahead and replace the terminal in case anything happens in the future. The links are highly appreciated!
    As for the pt100, I am currently printing something, so I'll wait until it's done and check on that as well.
    Once again, thank you so much for your help!
    Hi, maybe old post, but I'm experimenting the same symptoms as @Nerdwarrior, cables were rechecked but my sensor sense ok till 60/70 degrees, then it start to fluctuate and reached the maxtemp error. Will check the block tomorrow, maybe I got the same issue.
    But my question is that I searched the web but cannot figure where is the bed pt100 sensor located, cables are ok, but its on the block or integrated to bed? (didn't think it in the block ...)
    Regards.
    Didn't mind, I found it on another post, its a SMT RTD component located just at the side of the block, will try to verify if the tracks are well.
    Asked myself if I could replace it with a oem component (pt100) glued to bed ...
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 17 replies
