Most people here print with PLA. But there are a few who print ngen. I've only printed a few dozen parts with ngen. You really need to post a photo. nGen is a higher temp material so it is a little harder to print than PLA. It's not as hard as ABS but the harder the material, the longer it takes to get good at it.
Without a photo I'm not sure but as far as "5 or 6 hours" that's normal for a part the size of my fist. 3d printer is slow.
Regarding "fragile and brittle" that sounds completely wrong with nGen. nGen is pretty strong normally. Like legos. Unless you consider legos fragile. Unless it is breaking along layer lines. If it is breaking along layer lines then the problem is that you aren't melting the layer below enough for a good bond. PLA doesn't have this problem which is one of 100 reasons PLA is so great. So if you have layer adhesion issues, raise the temp 10C and reduce the fan to lowest speed. If you have a um3 that would be around 3%. If you have a um2 that would be around 30%.
Please feedback to us more information along with a photo and what kind of printer you have.
S-Line Firmware 8.3.0 was released Nov. 20th on the "Latest" firmware branch.
This update is for...
All UltiMaker S series
New features
Temperature status. During print preparation, the temperatures of the print cores and build plate will be shown on the display. This gives a better indication of the progress and remaining wait time. Save log files in paused state. It is now possible to save the printer's log files to USB if the currently active print job is paused. Previously, the Dump logs to USB option was only enabled if the printer was in idle state. Confirm print removal via Digital Factory. If the printer is connected to the Digital Factory, it is now possible to confirm the removal of a previous print job via the Digital Factory interface. This is useful in situations where the build plate is clear, but the operator forgot to select Confirm removal on the printer’s display. Visit this page for more information about this feature.
gr5 2,157
