Quality printing problem
paul9
Posted · Quality printing problem
It look like a problem with the z axis to me
maybe you need to clean and lubricated both the Z thread and the vertical shafts
One other thought, depending on your feeder (I have a BondTech feeder) sometimes the internal feeder gears benefit from cleaning
    I have feeder bondtech, and I I cleaned and lubricated the z axis.
    Could be a backlash issue. Check the short belts on the stepper motors. Make sure they're fairly tight.
    An easy test for this is to print 2-3 concentric rings and see if they are truly round or not. See the image to the left here:
    http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#circles
    whats the Material
    what temp
    what slicer
    what size nozzle
    Material PLA
    Temp 208
    Cura 2.6
    size nozzle 1mm from 3D Solex
    Hi
    Thanks, today I have been upgrading to the belts attached to the stepping motors.
    PRINTING PROBLEM
    Today I have performed all the controls on the steppers of the stepper motors and also on the axle screws I tightened all the screws well and adjusted the straps as proposed on the following guide: http://support.3dverkstan.se/. ..ooting-guide # circles
    Setting Print with CURA 2.6.1 I have the following problem printing object is unacceptable, the object is cropped, cropped.
    Check just in case that the x/y are square
    https://www.thingiverse.com/thing:81415
    HI Neotko, How do I use it? Do I have to use more than one contemporaneous?
    Hi Robert,
    What is the (backlash issue)?
    Are my belts lining material on toothed wheels on which they are turning almost 3 years old, maybe should they be replaced?
    But I'm not a UM2 user. Seems that in theory your aystem should be aligned by double checking the black spacers on your printer:
    http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#misaligned-axes
    This guide also recommends a printed alignment tool to check and align. The video is for umo+ but is practically the very same on um2.
    Can someone send me the link where I can find all the information about the components used for Ultimaker 2?
    Thanks
    Yesterday I made prints after strapping the straps and after checking the straps of the stepper motors.
    The hollow print came pretty well when I went to print that I'm interested in filling high, I again had the big problems of geometric correctness.
    Today I did the print test with the circles suggested by Robert.
    It seems to me that they are correct.
    My problem is this, but I've already done this.
        • 24 replies
