Issue: After converting your .stl file to a .gcode file through Cura then setting up to print, but then giving you the Error tried to print out of printing area. Fix: 1. make sure print is in print area 2. if already in print area go to Profile then go to manage profile then go to printers on the left of the box then click on machine settings. This is the most important part, make sure under build plate Machine Center Is Zero has NO check mark next to it. 3. This provides the Co
