Hi @nzo
Where in NZ are you?
There are lots of 2 85mm filament in NZ. Yes the local stationary warehouse stock 1.75 but Diamond age which has very good quality filament.
Mind kits also stocks 2.85mm and there are a few others.
I also import some like colorfabb at a good price per roll if you order the right amount.
SandervG 1,519
Hi @Nzo, welcome to our forums!
It is true that by default the Ultimaker is designed to use 2.85mm filament (sometimes advertised as 3mm, but in reality, it should be 2.85mm).
Part of the reason for this is because we use a bowden tube system which means the extruder motor is on the back and pushes the material forward through a bowden tube. Having slightly thicker material makes it more rigid and easier to push forward through a bowden tube. @Labern, can you shed some light on where you usually source your filaments?
There are third party modifications that allow you to convert your Ultimaker to 1.75mm filament if you are interested.
