I'm not sure we are miscommunicating now. I was trying to compliment you, maybe the word optimistic isn't the right description. Anyway, I appreciate you sharing your experiences, and looking at the bright side of things!
You would need to create a connection to your home network, but I've read somewhere on this forum that this shouldn't be too difficult.
You need to setup a VPN to your home network. If you have a router that supports it it's very simple, I use a fritzbox and it only took me a few minutes. Have a look at the manual of your router.
If your router does not support it, here's a manual to set up a VPN using a raspberry Pi;
https://ultimaker.com/en/community/39542-um3-remote-monitoring-raspberry-pi-vpn-tutorial
kmanstudios 1,117
Well, that is my mistake then!! Hahahahaha!! And, yeah, I do hope my mistakes help others.
You need to setup a VPN to your home network. If you have a router that supports it it's very simple, I use a fritzbox and it only took me a few minutes. Have a look at the manual of your router.If your router does not support it, here's a manual to set up a VPN using a raspberry Pi;
Thanks!!
kmanstudios 1,117
This is the print that killed my cores. Well, I killed it, but it was the one that was printing when the humidity hit my BB core so bad. It took 5 days and 19 hours at 0.2mm Layer height to get this beastie out. Will take forever to get the PVA off, but that is ok. Thank goodness it is PVA and will dissolve eventually. But on the day the print failed, it failed at less than 1/8 of an inch into the print and 'circled the wagon' in the air for about 9 or so hours before I got home. Uggghhhh...But it printed. Now to wait and see. It is real spindly and I am not going to rush that one.
kmanstudios 1,117
I think I should look into that. But, the goal is to find the optimum situation that does not need much monitoring, for the most part. But being able to monitor and abort would be nice. I have learned that tech fails at the worst times.
I will have to look at that. But, I do not know where you get optimistic from. I prefer all my systems, except this one to be air-gapped. There are just too many bad actors who do nothing but want to create chaos and have no concern for what they do to us little guys.
But, I do love sharing the experience as I am hoping it will help others. And, I thought the higher experiencers would get a good laugh at it. I certainly do now. Did not Monday night though!! LOL:P
