size of filament 2.85 to 1.75
Posted · size of filament 2.85 to 1.75
I have read the source code (GREAT) and it seems that the UM2 + can change and use the size of filament 2.85 to 1.75 from the menu (CHANGE | MATERIAL)?
Is it correct ?
When printing from the USB port l Does UM2 + use the menu settings (CHANGE | MATERIAL)?
Is it correct ?
The command (M200 - Set filament diameter) seems not to be implemented?
Is it correct ?
Is it possible to create this command (M200) and will USB printing use the new parameters (subject to calculation just !!) using the procedure as in the menu (CHANGE | MATERIAL)?
Thank you for taking time to answer me
philippe
PS:
To compile a firmware for MOTHERBOARD 72 with the github code it needs more compilation parameters for ArduinoDev , and/or change some #define
or just COMPILE and UPLOAD?
