While you are at it, is there a way to reduce the amount of support material used? Reduce the density? In this case the amount used seems to be overkill.
kmanstudios 1,120
The 'square' on the right/back side of the buildplate is the priming tower. It is placed there to prime and wipe the nozzle. You can disable it by going to dual extrusion and unchecking it.
Play with the support settings to minimize the amount of support. Density, step size, type, etc. But it is going to go from base to supported model...that is its purpose. I think there is a way to use another model to help with that, but you will always have something that has to go from buildplate base to bottom of model.
Edited by GuestThanks for the help. I just realized that there are a bunch of Setup features that are normally "hidden". That helps a lot!
One more question. Why did Cura generate that support tube that runs up the middle and doesn't support anything? On the other hand, why didn't it generate a cylinder to support the middle circular bearing?
kmanstudios 1,120
Yeah, I had to unhide them all to keep meself from going bonkers.
nallath 1,117
Do you have a screenshot of what you mean?
