I just set mine up.
Followed the video on the octoprint download page.to set up my raspberry pi.
I used the Pi camera with a long cable.
I had a bit of trouble with the API, I found it's best to scan the barcode with your phone and use the number that shows as on my computer I couldn't see all of the numbers in the code.
Edited by Guest-
1
ahoeben 2,047
I wrote the plugin you have read about.
In the sidebar, click on the name of your printer, and choose 'Manage Printers...' from the dropdown. Or open the Preferences window and navigate to the Printers pane. Once there, click on the 'Connect to OctoPrint' button.
In the window that pops up, with a bit of luck, you can select your OctoPrint instance. Before you press the Connect button, make sure you enter the API code. You can look this up in the OctoPrint webinterface (in the settings window)
