Well, much the same with me. I run a print, then if I want to run a second print, I get "Serial Timeout exception" and the machine cannot connect anymore. Unplugging the usb cable, turning off the printer, restarting CURA, nothing works except a total restart of the computer.
Pronterface works all the time though....any ideas?
gr5 2,157
This happens to me a lot so I usually print with the ulticontroller. Much more reliable.
I don't have an answer for you, sorry. Oh - I found it helps if I set the print temp to 0 because it most often loses connection when waiting for print head temperature to stabilize.
