Is the hole bigger or the width will not fit the adapter with threading holes (That hole at the bottom of the arm with the smooth, white inserts).
If the hole is bigger, just put it on the spool holder and it will just roll. There is a 'lip' that will keep it from falling off.
If the width (From front to back, not in diameter) of the roll is too large for the adapter to fit into, then just put it on the spool holder as above.
In both cases, (I have some filament for which the spool is too wide for the adapter) I just put the spool on the spool holder and thread the filament through the holes in the adapter and just let it hang. Gravity will do its job there for the most part. Worst case, you may have to tape it down to keep it from rising up to the feeder.
I have adapted the spool holder with a piece for the smaller hole spools like Taulman's, but have not played with the printing of an adapted spool holder for the wider spools.
I use filament spool with a larger "tunnel distance" from front to back in the hole.
However the hole size in diameter just about right to fit into it, being a little too tight.
So it's feels like it's gonna break any time.
kmanstudios 1,117
