cloakfiend 990
My tip is to NEVER pause regardless. That way you don't need to worry about it.
Try older versions of cure maybe if you are desperate? But I would highly advise against any pausing mid print, purely from a quality point of view.
Haha that is very good advice - I am finding pausing quite challenging.
What I did do is create a dummy structure some 150 mm away, just a thin-walled square profile, and then at the height I want to pause, add a one-layer-thick roof. This keeps the print head away from the real part, and gives me enough time to pop the metal parts in.
Hope this helps somebody else. I'll do a separate post explaining it in more detail.
Cheers,
Matt.
you could try to do this manually: before resuming the print, lift the white lever of the extruder and push the filament until it hits something. This will undo the retraction before the pause, it seams like the gcode doesn't compensate for this when resuming.
I'm so sorry I didn't see this reply! That is a really good idea, I haven't long upgraded to the UM2+ and I often forget about the magic white lever!
Thank you very much, I shall give this a go.
Cheers,
Matt.
peggyb 169
