So it wasn't so much the bed leveling. However it was build plate calibration. Even when you follow the instructions, there is a difference between a loose/subtle fit between the nozzle (with the card) and a snug/tight fit. Once I adjusted it to a tight fit, my target values were pretty much right on the designed values.
IRobertI 517
Tweak your bed levelling a bit? Still, I would say two tenths of a mm is pretty decent...
