Creating install file for Cura with custom printer settings?
Posted
· Creating install file for Cura with custom printer settings?
If you're feeling up to it, you can have a look at our Cura-build repository. But this is not for the faint of heart. Quite a bit of experience is needed to get that running properly.
This also means that for every software update, you would also need to make new packages.
If you don't feel like that, putting them in the local folders is the best option. Those are also upgraded if a newer version is installed. An easy way to install a local machine on multiple computers is to use project files.
A final option is to make a pull request that contains the machine that you have as a definition. The next Cura release will then have that machine and others can also benefit from it.
nallath 1,117
