Well there are a few things you can try. Basically 2 ways to success. The first way is to fix it in sketchup. In sketchup you have the default walls (which is good) which are gray on one side and white on the other. You can click on any wall and reverse the faces (gray in, white out, or vice versa). Make sure all walls have white facing out. More fixes here:
https://i.materialise.com/blog/3d-printing-with-sketchup/
The other way to fix things (or maybe you have to do this even if your model is perfect) is in cura. There are settings in the section "mesh fixes". If your model is perfect cura can fill in parts of your model like the photo above unless you turn all of these off. Click the gear and locate these (second or third to last category in cura and make them all visible). It's probably the "union overlapping volumes" on that is the problem and needs to be unchecked. Although if you fix things to make all visible faces of your part "white" then you might not need to mess with this in cura.
Hi gr5,
thanks for your help. I have tried to follow all the steps you supposed. Here is the result:
Sketchup changed faces:
Cura with no meshmix settings:
Cura wit meshmix settings:
gr5 2,330
