Hello, so I have an idea to save the amount of PVA that is used to print supports without compromising any quality! Last time I checked, PVA is significantly cheaper than a main material like PLA. What if you printed only the bottom and top of the support column in PVA, and print the tall, wasteful part in PLA. I this way, you can through the print in a bucket of water, and the PLA column of support will break free from the part after the PVA on the top and bottom of the part dissolve away.
