Dim3nsioneer 559
Can you exclude someone was manually aborting the print?
That is a good point. Well, we are a robotics club associated with the school. And, the school is on summer break, and no one should be in the class room. But, we can't completely rule it out. But, it is fairly unlikely.
First, update to newer firmware. From the logs I gather you were printing using 3.6.3.20170406.
Latest stable is 3.7.7.20170627
I notice a small issue with the internal database which likely caused the abort of the print.
gr5 2,334
I have no idea why that would happen. That particular error has never happened to me. However I do suggest you print the version of the eiffel tower that is in 3 pieces. That is what I did. They glue together nicely and once it got dropped and I only had to reprint the top third (which is also the fastest to print - only 18 hours for me.
I have had problems with the USB stick the UM supplies where the print stopped part way through and when I checked the file on the USB was corrupt. I started testing the gcode file on the USB everytime I wrote a gcode file to it and I *STILL* got corrupted files later that had been fine. Eventually I changed USB drives and things have been fine since. But I got a different error than you got. But still - check the gcode file - compare it to the version on your hard drive (you did save it, right? If not - that's a good habit).
Edited by GuestLink to post
gr5 2,334
Here is the image of the display:
