ahoeben 1,948
Are you sure you are talking about the nozzle diameter? The filament diameter has this issue, but the nozzle diameter should work just fine.
The filament diameter gets overruled by the diameter set by the material in Cura 2.6.x. This should be fixed for Cura 2.7
