Technical data sheet Ultimaker 2
Posted · Technical data sheet Ultimaker 2
Hello everyone..
Who can help me find the complete technical manual of Ultimaker 2 I need to know what kind of straps they used because I would like to replace them with old ones and buy new ones.
    Do you think I can buy new straps for my Ultimaker 2?
    You mean the belts? Sure. Please contact your Ultimaker reseller. He should be able to get them for you if he does not have it on stock.
    Yes the belts!
    Last year I decided to convert my ultimaker 2 into version 2+.
    Before the conversion I saw that 3D Solex offered the possibility of converting it also for 1.75mm filaments and then I decided to buy the Olsson extrusion kit for 1.75mm filaments then I also bought from Bondtech the filament feeder for 1 , 75mm and since I converted the machine I have overextruder problems, I had to reduce the flow from 100% to 65% with 0.6mm and 70% nozzle with 0.4mm nozzle but despite all I can not make perfect prints like It was first with filaments of 2.85mm.
    What can depend on this problem of having too much material flow?
    uhmm... would you mind posting rather different topics in different threads? People who come later with maybe the same question find the answer much easier if you separate the topics.
    ok
