I have the same problem with an interesting twist. I do gang printing of a small object. When I print 18 up "One at a Time" it prints perfectly. When I print 66 up "All at Once" It prints the second layer a negative value (the same every time) on the Y axis.
This seems like a slicing (software) issue and not a hardware issue. Any suggestions?
gr5 2,331
See this guide:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
So is it both axes or just one axis? If just one axis then which?
This is almost always caused by a loose pulley that screw you pointed to needs to be incredibly tight. The tool you use - it should be scary tight. if you have an L wrench it should really hurt your fingers. If you have the screw-driver like tool it should almost twist the steel.
Make sure you get ALL the pulleys on the given axis. One axis has 5 pulleys, the other has 6.
Having said all that there is a tiny possibility your stepper drivers overheat and shut off for part of a second occasionally. This is more common with Z axis. Not common with X or Y. But theoretically possible. Consider lower the current.
More likely there is also a possibility that your friction is too high or acceleration or jerk parameters. Are you using cura?
I think default jerk and accel for XY is 20mm/sec and 5000mm/sec/sec which should be quite safe values to use. Did you mess with these?
Check friction - push the head around with your hands. Add one drop of oil to the 4 larger rods and the 2 smaller rods. The 2 smaller rods shouldn't really need oil in theory but I found in practice it seems to help. Check that the smaller rods that go through the head are perpendicular by pushing the rod to each of the 4 sides to see if the end blocks on the rods seem to reach their end point at the same time. Sometimes this is crooked and adds lots of friction.
You should be able to move the head with only one finger on each hand pressing on the side blocks.
