Heatplate and nozzle doesn´t heat.
Knobler
Posted (edited) · Heatplate and nozzle doesn´t heat.
I got within one week a total loss of all mainfunctions of my UM2+ as:
   the heatplate didn´t heatup anymore
   a few days later the nozzle didn´t heatup at all
So no printing doesn´t start anymore, even as curiously the heating works in the advanced maintenance menu.
My idea is, that there may be a defect with the mainboard. Or has somebody a better idea or fixed a problem like this already.
    Posted · Heatplate and nozzle doesn´t heat.
    If the servos also don't move then it's the 24V relay also known as K1 which really has no purpose (it was never utilized) so you can short the 24V across it. I did that for one of my UM2s.
    But since it sounds like your failures happened slowly I'd say the cause is something else.
    Do you know someone who has a volt meter and knows electronics? I would invite them over. The circuitry is pretty simple. Similar to a light switch and a light bulb.
        • 4 replies
