Cura 2.6.2 Retraction Settings
JstWantoRide
Posted · Cura 2.6.2 Retraction Settings
I just started using 2.6.2 with my new UM3. Previously I was using 2.3 with my UM2.
My UM3 has a lot of strands all over it after a print. With my UM2 and Cura 2.3 I would adjust the retraction settings to get rid of those but I can't find that in 2.6.2.
Is there a way to adjust the retraction settings in Cura 2.6.2?
    Should be under Material -> Enable Retraction
    If you don't see it there, you may have to enable all option:
    Preferences -> Configure Cura -> Settings -> Check All
    Hope this helps.
    A better tip is to use the search box on top of the settings in the sidebar. I would strongly advise against just making everything visible because it gets overwhelming quickly. Just make the settings visible that you use often, and use the search for the rest.
