Just running another test without the smoothers. And the temperature of the bottom side of the board (under the stepper drivers) is the same, you can't touch it.
I did some tests with my cheap Seek addon from iphone (the old model) and the temperature with and without is around 10-25C higher with the smoothers after 1h of print time.
Also indeed doesn't make sense to add smoother if you already did the complex solder fix. You are just changing the stepper waves and it might add errors like you get.
Edit. Also as a general rule for um2/um2+ boards is a good idea to add a heat sink for on the stepperchips since they have poor natural heat sink on the plastic cage. For example for UM3 Ultimaker changed how the board is aligned (flipped 180 degrees like on UMO+) and added a grey sticky thing that heatsinks the back of the stepper chips into the aluminium frame.
Top Posters In This Topic
25
12
11
8
Popular Days
Mar 19
13
Oct 21
8
Dec 11
7
Oct 13
5
neotko 25 posts
conny_g 12 posts
mutley3d 11 posts
halfie 8 posts
Popular Days
Mar 19 2018
Oct 21 2017
Dec 11 2017
Oct 13 2017
Popular Posts
cjs
The Duet3D board doesn't have the issue! One reason are the newer, more advanced, stepper drivers @nilrog mentioned. Wonder why ultimaker still doesn't set the a4988 to low-current microst
halfie
I'm using the aliexpress 2.1.5 board at the moment, and it's working just fine. What I did was change the MS1, MS2 and MS3 microswitches to OFF/OFF/OFF, to make the board full step, and t
mutley3d
I am looking into that board and have contacted the seller to request TMC drivers with it, along with some spares. I suspect you may well have had the voltages set incorrectly on the drive
Posted Images
conny_g 251
