What is the highest printing temperature for Ultimaker?
awydra
Posted · What is the highest printing temperature for Ultimaker?
Hi guys,
I was thinking to try do do some experiment with printing with polycarbonate. I even found a nice source (see link below):
https://ultimachine.com/content/polycarbonate-3mm-clear-1lb
The only thing is that on the website they recommend to print at 265 C... Do you guys think that Ultimaker can do it? ...or it will just die suddenly :eek: ?
    trion, you are probably right... any ideas which parts are the most sensitive to the high temperature? ...Maybe I can somehow modify my Ultimaker to be able to print at higher temperature?
    The white PTFE (Teflon) element at the top of the hot-end is sensitive to high temperatures. The PEEK element down below can withstand temps of about 300 °C.
    If you modify the hot end a bit, to limit the heat reaching up into the PEEK, you can go to 270-280 C (after FW mod):
    Heat sink 1Silicone Foam InsulationHeat sink 2Hot end installed
    Not according to my experiences or this data sheet, which says max. long-term temp for both PEEK and PTFE is 500F (260 C).
    http://www.plasticsintl.com/sortable_materials.php?display=thermal&sort=heat_deflection66
    I discolored and slightly deformed my first PEEK running ABS prints at 265-270C. With my current setup, similar to Joergen's hot end, I print Ultimachine black at 275 C.
    I molded a PEEK replacement out of Hi-Temp Lab Metal compound. Though it's somewhat fragile (it's a filler and molded parts is not its intended application), it's good for 1000 F. I don't really need it right now and if I had some Macor ceramic laying around, I'd machine it into a PEEK replacement.
    Thank you, guys. It looks like I will have to slightly modify my Ultimaker and then printing with polycarbonate can come true.
    Joergen, on the photos of your upgraded hot end I can see a small radiator between the hot end and the PEEK. Did you buy this element or you made it yourself? ...and another question, that 'silicone foam insulation'... what is it for? I could understand that you want to isolate the hot end from the PEEK... but this foam just cover the hot end from outside and does not insulate from the PEEK.. so can you please explain me the physics behind this element?
    I thought I outlined all the info at http://umforum.ultimaker.com/index.php?/topic/1925-modification-to-the-hot-end-for-abs-printing/
    let me know if something is left unclear in that post.
    The silicone foam limits the heat bleeding from the alu into the air, keeping the temp more stable, and lessening the cooling effect the fan has on the heater. you know, insulation.
    Thank you, Joergen. Right now everything is clear! It's just my fault that before I didn't read the forum carefully... sorry for that.
    The silicone foam insulation also makes sense. It just helps to keep the stable temperature which for sure it's a very important thing to print better. ...Before I was just confused because I thought that it also insulates the PEEK but it actually has nothing to do with that... and the part which improves the printer temperature resistant is the radiator.
    Anyway, both upgrades (radiator and silicone foam) are very interesting and sooner or later I have to proceed with them :-)
    Ultimaker headquarters has emailed me saying that Ultimaker 3 can safely go up to 350°C. I have been testing out PVDF for the last couple weeks using 345°C. It seems to be okay. Between 345°C and 350°C the software starts to give temperature errors
    Dude, what brand of PDVF are you using? I use Nile Polymers PVDF and can print at 240-260 C
    Be aware that you will probably get a color change at your print head with temperatures around 300 degree or higher.
    The Ultimaker 3 should only be used up to 280°C, we don't support higher temperatures. Going above 280°C will degrade your silicone flaps really quickly, reducing the reliability of your printhead. The emissions of the printing process also tend to quickly rise when increasing the nozzle temperature, so watch out for VOCs and Ultrafine particles! Especially with PVDF, which should melt at lower temperatures. Printing outside of the printcore specifications could also reduce the lifetime of your printcore.
    The errors showing up are probably because you are working at the edge of what the heater can handle.
