The printer comes with more narrow spools but they are more like samples. The spool holder still holds the standard sized 750g - 1kg spools
Edited by GuestIt does not appear to fit non-UM spools. My MH Pro ABS spool only fits on one direction. I printed a top mounted single spool holder and so far it is serving its purpose for now.
kmanstudios 1,117
Did you use the file link to print a piece?
Another work around would be to flip the AA and BB cores in the slots and then flip the Print material and support material in the back to spool in the proper direction.
Most of my rolls are non-UM and all fit but there are some odd companies that make theirs slightly different.
Dim3nsioneer 556
Some spools have a hole diameter of 52-55mm, some a bit less. The latter can cause trouble with the material guide of the UM3. Even some UM spools (e.g. the spool used for TPU95A white without NFC tag) are affected. With a bit(!) of additional force they can be mounted.
kmanstudios 1,117
If you are referring to the spool insert to hold and feed the spooled filament, you can find a version to modify and print here.
