When you opened the png file did it ask you questions like how large to make it, how thick, and so on? It may be that you made it thinner than even one layer? Try dimensions such as 100mm by 100mm and 5mm thick.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
