Unfortunately, no substantial change with all 30mm/s speeds (tried both default 120 and your suggested 150mm/s travel). Here's the print with 30mm/s print speed, except 150mm/s travel. All other settings are draft 0.2 defaults, plus 1.2mm walls and 30% grid infill.
Print speed settings:
Everywhere else on the print is fine except the screw hole to external wall transition, and the same part minus the screw holes prints fine at any of the settings I've tried..
Here's a partial print with 50mm/s main speed and defaults (120mm/s travel speed):
I was pretty sure the ooze on the infill is what's missing from my outer wall, until I turned off combing, which removed the ooze but didn't fix the under-extrusion:
Added print speed settings screen cap
gr5 2,333
Try lowering all the printing speeds to 30mm/sec (all of them except travel speed which needs to be at least 150mm/sec). That will fix it I'm sure. Then you can experiment with increasing the various speeds (there's several of them).
