Posted · Weak infill issue
Hello,
I have a common issue : the infill of my prints is verry bad.
I know there are different topics on it, in general the solution is to reduce infill speed.
But actually I set the same speed for layers / infill / supports : 40mm/s
Supports and layer are all ok, but infill is verry bad, like this : Weak-Or-Stringy-Infill.jpg
In cura, what is the difference infill vs support in GCODE ?
I mean both are one line but support is verry good and infill is bad, why ?
I have this issue after Cura 2.3 if I remember well (now 2.6.2)
thanks for your explainations and for solutions if you have
regards
Spilz
