Part start cracking while printing.
clover3dworks
Posted · Part start cracking while printing.
Recently I facing a problem on my printing parts. The part start to crack during printing, and getting more serious after cooling down.
Material : ABS
Profile : Normal
Layer Height : 0.2mm
Wall thickness : 1mm
Top/Btm thickness : 0.75mm
Infill density : 10%
Material enable retraction : YES
Printing speed : 55mm/s
Travel speed : 150mm/s
Enable print'g cooling : no
What is the root cause of this problem
    Poor layer adhesion?  What is the print temp?
    Perhaps try 20% or 25% infill?
    What is the infill pattern?  You might want the infill pattern to be at a 45° angle to the layers.
    Hi, thanks for advise. Yes, poor adhesion, or like warping after cooled down. While it happen during printing as well. Nozzle temperature is 260 degree, mostly I follow Cura standard setting.
    Yes, you are right, I should try, to increase 20~25% infill.
    How about layer and wall thickness? Any effect in this case?
    Why ABS? Have you tried PLA. Much more forgiving. My advise, if you are just starting out in 3D printing, work with PLA for a while until you gain some experience.
    ABS likes to be kept warm to hot throughout the process. Do you have an enclosure for your printer?
    • 4 weeks later...
    That's a very common problem with ABS, I eventually abandoned it in favour of PLA, even though ABS was the better material for the project. Since switching, the delaminating dropped from 50% per print to 0%. PLA is SO much easier to print.
    As far as I understood, the basic reason is that ABS requires a very hot temperature to melt and fuse well. The new layers tend to cool down too fast, thus without proper fusing to the previous layers. You need to keep the temperature of the old layers way up too: close the front of the printer, switch off cooling fans, high bed temp, and don't print too fast. In combination with the huge shrinkage of ABS, this causes the splitting, or the coming loose from the build platform. ABS is good for injection moulding, but not so good for 3D-printing.
    If PLA would not be suitable for your model, you might consider materials that have less shrinking and warping than ABS, but that print more like PLA. For example NGEN, PET, PETG? Try one spool, or even a sample, before buying a lot.
    Completely agree with you. I should change my setting and try again.
    I have try with PLA, much more easier, no problem at all. But just facing a problem that how to smoothing PLA printing. As I know, chloroform is the best choice, but hard to get it.
    Concerning PLA smoothing, if you haven't done so, I would recommend that you read the thread about PLA smoothing created by user cloakfiend. This has lots of good info and photos (so you can verify the results). He is the specialist on PLA-smoothing. This thread contains about all that is known about this subject.
    It should be this:
    https://ultimaker.com/en/community/10412-acetone-finishing-on-pla
