The firmware is this one:
https://github.com/Ultimaker/Ultimaker2Marlin
I didn't find any guide to modify E-steps to fit UM2+, so I had to adjust it by trial and error. The knurled wheel seems okay, it is not an issue of slippage but more that the motors are alternating between slow/fast and making weird Star Wars noices.
I am convinced it is a matter of the firmware, perhaps it has to do with maximal speed/acceleration of the E-stepper not being changed. Does anyone have the value of these? In the meantime I will have a go at adjusting those.
SandervG 1,509
What firmware did you install? And weird sounds at the end...
Can you check if the knurled wheel is properly secured? There is a little screw that is suppose to prevent it from rotating on the shaft (some/most E-motors have a D-shaft, dunno about yours). It could be that it is not secured properly.
I also see that you set your indicator at the far top. It should be in the middle.
That is all I could think of right now.. good luck!
