Thanks for the reply:)
We've printed various objects with the same results as shown.
Minimal crackling and popping sounds. We adressed this anyway by drying the filament in an drying oven for several hours at 75 degrees celsius.
The first print, started minutes after unpacking the filament and with the default nylon profile, came out good:
The second print and the prints after however failed. Therefore the tweaks in print setup and material settings.
Things we've tried:
- Loosened the grip on the filament to reduce grinding
- Atomic method and cleaned the nozzle with a needle - thickness of layers seemed smaller than it should've been and we thought some blockade may have caused under-extruding
- Printed with other materials in between to make sure nothing was wrong with the printer
- Recalibrated the build plate
Any ideas and tips is appreciated
Labern 772
Have ypu tried printing a simple test object with Nylon?
Did you hear crackling and poping sounds as it was printing?
What were the results like using the default profile?
In my experience the moisture content in the nylon plays a big part on how well it prints and making sure it's nice a dry can eliminate more issues I'm seeing in your print.
