Slow performance in Cura 2.5 and up - once Object is sliced
JimE
Posted · Slow performance in Cura 2.5 and up - once Object is sliced
Using Cura versoin >= 2.5 -- I load an object into Cura and while looking at it in normal view - I can rotate / zoom / etc with nice smooth motions. Then I slice it (or it auto slices) and suddenly it acts like i stepped back 3 generations in a processor. The normal view does jumps vs smooth rotation - and sliced view is absurd trying to get to a layer or rotate the image.
This did NOT occur with Cura 2.4 or earlier.
I read that Cura2.5 started using multiple cores - so I restricted my version to a single core - NO change.
Now the magnitude of this is very model dependent. A simple box or such is "just detectable" - but get a complex model with supports and such - and it goes to its knees.
This is very challenging as I really want to stay with Cura and some of the great features being added - but this slicing view issue prevents usability.
Help :-)
    2.5 also has the "realistic" layer view. Did you try forcing it to be in compatibility mode? It could be that your graphics card doesn't like those new shaders and slows down a lot.
