How to control the work of um3 from the internet?
teleporteur
Posted · How to control the work of um3 from the internet?
How can we view the UM3 camera from the internet and give a stop command in the event of a problem?
There is the application "Ultimaker 3 app for android" but it only accepts wifi connection and no setting to go through internet
Thanks
Alain
    • 3 weeks later...
    • 2 weeks later...
    @teleporteur I don't that's possible yet. We've solved the problem here by buying a WeMo. It can be turned on and off through the web, and the printer is plugged on it, so we can turn the printer off at a distance if we realize that a nightly print has gone sideways.
    Posted (edited) · How to control the work of um3 from the internet?
    Actually, you can, using the WEB API:
    http:///docs/api/PrintJob/put_print_job_state
    You can send an abort or even a pause command to an active job.
    To send commands, you need to be authenticated though, and for that, you need physical access
    Your http:///docs/api/PrintJob/put_print_job_state display the wifi setup page of the UM3 ...
    You do not get a page where you can stop printing.
    My UM3 is connected by cable rj45
    Actually this was a link to the documentation.... but it seems that the path has changed a bit (at least for firmware 3.7.7). The correct link should be:
    http:///docs/api/#!/PrintJob/put_print_job_state
    Anyway, you have always access to the full API Documentation directly from the printer:
    http:///docs/api/
    it seems that it is a function to integrate in web pages to put in a website?
    Would you have an example of a page to get started, not being a java script specialist
    Someone would have an example of a page showing the status of the UM3 with a STOP button ... that I could put in a website (private) plus I have a fixed IP address at home
    Not a complete example for your question, but it should help you understand the used techniques: https://ultimaker.com/en/community/23329-inside-the-ultimaker-3-day-3-remote-access-part-2
