Thanks gr5,
thats unfortunate. Going through a webbased system does not work for the MakerSpace how we are operating it right now. We can't hook all theses devices up to our Company Net.
I'd be happy to hear more suggestions if you happen so see other solutions.
Cheers!
gr5 1,871
I strongly recommend octoprint. Not only does it cost only about 25 euros for a rasberry pi but it can handle the webcam in addition to everything else (preheat, print a job through a web page, monitor printer through a web page and so on).
Octoprint does this through the USB so obviously you *can* do everything through the USB.
I recommend you switch over from SD cards to octoprint web page.
But to answer your question, you can ask the printer it's X,Y,Z,E location through one gcode and you can ask what it's goal temperatures and actual temperatures are through another gcode. You can keep sending these gcodes every few seconds. This should be enough information to decide if it's busy or not. It might be more likely that the printer will hang up/crash if you are doing all this during a print. Not sure.
