Dim3nsioneer 557
just make sure you have an Ultimaker mainboard with 5 stepper drivers installed.but
Don't really get that, are you saying make sure I have a spare board in case I blow it OR are you saying count the drivers and make sure it original UM board??
this was My mother board last time I had it to bit's.
no I have not seen that version, is it better ??And also... Yes there is still development. Did you see the zge version?
Your board is fine. Some of the newest um2 are missing components of the 5th stepper driver. Ultimaker claims they had to do that due to lack of components.
But your board is fine. You can see it has solder at the back where the 5th driver is.
For the zge... It looks assom but is a much bigger makeover... I suggest you try the normal Mark2 first. Search for zge mark2 on this forum for more info... (On my phone... To hard to find a link..)
https://ultimaker.com/en/community/35608-zero-gravity-direct-drive-extruder?page=1
fyi, here's the link to the regular ZGE setup.
and the link to the MARK2 ZGE topic;
ultiarjan
thanks for that I will take your advise and stick to the plan of the Mark 2.
ultiarjan 1,222
Sure. Everyone involved is still around. Ofc everyone has a day job.... But you can safely go one with the mod.. even if you would have to wait a while for an answer your single extrusion ability stays just as is.
And yes you can use s3d.
