Hi gr5, thank you for your comment. And sorry for my late response, I've been busy at work!
We are indeed printing with a high temperature material, in the case of the measurements with white PC. I understand that we can 'boost' the temperature by covering the machine. But should that be necessary? It looks obvious to me that the printer should be able to warm itselve up to more than 90°C, but I can be wrong. Also, we've printed with PC and many other materials before without this problem.
By the look of your posts, points and owned printers. Could you tell me if the temperature raise on our printer is considered 'normal'?
Also, I've made a screenshot of the notification we get from our UM3E.
Looking forward to your response. Thank you!
gr5 1,870
I assume you are printing ABS or similar high glass temp material. It can be printed at 90C but it works MUCH better at 105C to 110C. To get it up to that temperature you basically need to cover the machine.
For example sometimes I use a 1 gallon plastic bag (with nothing in it) to cover the *front* of the machine (Ultimaker sells a nice front cover as well). And for the top of the machine I use those boxes that copier paper comes in. It's the perfect size. No cutting necessary. Flip it over onto the top of your UM3 such that there is a big gap towards the back for the machine to let the bowden in.
