Another option would be to take a ruler and measure it. And then draw the thing in whatever CAD program you want.
hi
I have them. as I've already made a perspex front for my machine. I'm in the process of getting all the files together & sharing the info on here..
edit .. my apologies I read your initial message wrong I have the front dimensions etc but not the top. although I'm sure it wouldn't be hard to measure
Edited by GuestWhy would you measure anything if the cad files are on GitHub? Many cad programs let you easily grab the faces of the .step model and save as dxf for example to use in your CNC software.... If you only need dimensions it's also easy to measure accurately in cad. Use f.e. the free fusion360.
1
Dim3nsioneer 556
What about https://github.com/Ultimaker/Ultimaker2Extended? You should have step files for each part there.
