Could you share the logs? See https://github.com/ultimaker/cura#logging-issues
There is nothing here:
$User/Library/Application Support/cura//cura.log (OSX). So I tried running it on the command line and got the trace:
Error in sys.excepthook:
Traceback (most recent call last):
File "", line 969, in _find_and_load
File "", line 958, in _find_and_load_unlocked
File "", line 673, in _load_unlocked
File "", line 665, in exec_module
File "", line 222, in _call_with_frames_removed
File "/Users/ultimaker/build/2.7/build/inst/lib/python3.5/site-packages/cura/CrashHandler.py", line 10, in
File "ExtensionLoader_PyQt5_QtCore.py", line 22, in
File "ExtensionLoader_PyQt5_QtCore.py", line 14, in __bootstrap__
File "/Users/ultimaker/build/env/2.7/inst/lib/python3.5/imp.py", line 342, in load_dynamic
ImportError: dlopen(./lib/python3.5/PyQt5.QtCore.so, 2): Symbol not found: ___sincos_stret
Referenced from: /Applications/Cura.app/Contents/MacOS/./libQt5Core.5.dylib
Expected in: /usr/lib/libSystem.B.dylib
in /Applications/Cura.app/Contents/MacOS/./libQt5Core.5.dylib
Original exception was:
File "/Users/ultimaker/build/env/2.7/inst/lib/python3.5/site-packages/cx_Freeze/initscripts/__startup__.py", line 12, in
File "/Users/ultimaker/build/env/2.7/inst/lib/python3.5/site-packages/cx_Freeze/initscripts/Console.py", line 21, in
File "/Users/ultimaker/build/2.7/build/inst/bin/cura_app.py", line 54, in
File "/Users/ultimaker/build/2.7/build/inst/lib/python3.5/site-packages/cura/CuraApplication.py", line 4, in
File "ExtensionLoader_PyQt5_QtNetwork.py", line 22, in
File "ExtensionLoader_PyQt5_QtNetwork.py", line 14, in __bootstrap__
ImportError: dlopen(./lib/python3.5/PyQt5.QtNetwork.so, 2): Symbol not found: ___sincos_stret
Any clues here?
Thanks,
DLC
nallath 1,125
